Salta al contenuto principale
The Acer Chromebook CB5-132T-C8ZW was one of the first models to be released. It was released in June 2016.
Chromebook doesn't turn on occasionally
Acer chromebook doesn’t turn on. Its not an issue with power adapter. I opened the back cover and disconnected the battery cable/wire and reconnected it. Then it starts working for few hours. After few hours it doesn’t turn on again, I don’t even see any light for power/battery. I’ve to open back cover again and remove/reconnect battery cable.
Has anyone experienced this? Is battery an issue? Is cable bad? or something else? Btw, chromebook works on battery as well and battery lasts well.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
when my Chromebook does this I try plugging it in and if that doesn’t work then I try holding the power button down at least for 10 seconds.
Punteggio 0
Aggiungi la tua risposta
James Bond sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 61
