Why Nuvi suddenly stopped functioning?
Why no power, blank screen?
Questa è una buona domanda?
Hi,
Do you get any indications on the screen that the battery is charging when connecting a power source to the device e.g. the vehicle power cable, a mini USB cable connected to a computer or an appropriate AC adapter with a mini USB cable connected?
If not use a strong light and a magnifying glass to check that the mini USB connector on the back of the device is OK i.e. that the port enclosure is not blocked with dust/debris etc or that there is damage to the pins.
If the mini USB port seems to be OK then the device will have to be opened and further inspected
If it shows that it is charging but won’t turn on try holding the Power button operated to see if this resets the device.
If still no good and it won’t start with a charger connected either then perhaps the battery is faulty and may need to be replaced.
Here’s a video that shows how to replace the battery in a Nuvi 1450 which may help. I realize that it is not exactly the same model as yours but the should be similar enough to be of some use.
Replacement batteries are available online. Just search Garmin Nuvi 1400 battery to get results for suppliers that suit you best.
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 15
Tutti i Tempi: 343
