Salta al contenuto principale
Repair and support for the controllers that shipped with the PS3. Released in November 2007 (Japan only) and 2008 (other countries), the six-axis lithium battery powered controller (CECHZC2) is straightforward to repair.
Why doesn't my PS3 Controller Pair?
I had my PS3 controller disassembled so I could clean it. Once I had it cleaned and reassembled, I went to power it on and I could not get it to power on with the Sony button.
I powered it on by plugging it into my PS3. It turned on with four blinking lights, but after ~15 minutes it never paired with the PS3. I disassembled it and clicked the reset button and re-seated the battery, but these didn’t make a difference.
Any clue as to what may be causing the issue? This controller was working perfectly before I disassembled it.
Questa è una buona domanda?
Punteggio 0
1 Commento
Can you try rebooting your device?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The ribbon connector that connects the button membrane to the motherboard wasn't making contact on my controller. There is actually a little rectangle of black padding that goes between the white plastic shell and the ribbon cable. There is even a groove in the plastic that the pad fits perfectly into. It had fallen out and I didn't know where it went. But as soon as I placed it back in, the controller powered back on and turned my console on.
Punteggio 0
Parti & Attrezzi Popolari
Acquista tutti
Aggiungi la tua risposta
Jesus Garcia sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 156
