Salta al contenuto principale
Guide e informazioni di riparazione per i robot aspirapolvere Neato.
D85 Botvac: clunking noise while operating.
D85 Botvac is working fine, but now has a loud knocking/clunking sound when maneuvering. It is intermittent. I service clean the brush and bearings almost every run. I have tightened up the wheel hubs, so that is not the issue. At a loss.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
So the clunking turned out to be the brush motor becoming loose from the brush gearbox.
I removed the gearbox from the D85 and put blue thread-locker on the motor mount screws. I also added a thin nylon washer between the main transmission gear and the gearbox.
Everything is perfecto now.
Punteggio 0
1 Commento:
where is the gear box
da
Aggiungi la tua risposta
Mike sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 5
Tutti i Tempi: 391
