Salta al contenuto principale
Lanciato il 4 novembre 2017. Modello A1865, A1901. Disponibile con GSM o CDMA / 64 o 256 GB / Colore Silver o Space Grey. Si pronuncia "iPhone 10".
Microphone problem after screen replacement
Hello.
When I replace the display with a new LCD, then I screw the tape with (speaker-microphone-face id etc), while recording the front camera I hear a slight squeaking in the background. But when the tape is on the outside of the screen, it is all ok. Is it maybe some kind of lack of grounding in the screen? Is there any method to change it? (in the original display everything is fine) Any suggestions or help are welcome.
Questa è una buona domanda?
Punteggio 0
1 Commento:
Yes, I checked everything. This little golden clip does not eliminate the problem. Flex is ok, everything works fine on the original screen.
da
Aggiungi un commento
3 Risposte
Did you place back the little gold grounding clip as can be seen in step 22 of this guide? Sostituzione schermo iPhone X
Also double check the flex cables to ensure they are not damaged.
Punteggio 0
1 Commento:
da
I have 350 of the same replacement displays, I checked 30+ lcd's and they all have the same problem. (little noise - “piiiiii” when i recording front camera)
Punteggio 0
This is an issue with bad quality replacement frames. Sometimes it is easier to use a good quality screen to save the hassle.
Punteggio 0
2 Commenti:
So you are saying that in my replacement displays, weak aluminum or other metal was used during production, which interferes incorrectly with the phone casing?
da
Aggiungi la tua risposta
Lucas Szeyk sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 21
Tutti i Tempi: 732
