Salta al contenuto principale
Un portatile da gaming Windows 8 prodotto da Asus nel 2012.
shuts down at loading files
had this from new 8 years, always had the shut down after 10mins issue, but today turned on no worries, started playing a game it ran slow then crashed, now it will turn on but crashes before loading windows, tried going into safe to reload same problem crashes , is this fixable or do i move on
Questa è una buona domanda?
Punteggio 0
1 Commento
ok, got into bios, said connect power, hmm it was, checked, no green light on adapter, removed replugged it green light came on, connected to laptop,popped the main circuit breaker, and now adapter will not power up, i'm guessing this is my problem, at least i didn't pull the laptop apart looking for a problem that was not there
da
Aggiungi un commento
1 Risposta
Risposta più utile
Hi
If you have Win 10 installed, try getting into the Windows Recovery Environment menus to see if you can so a startup repair.
There are two methods to get there.
a). Start the laptop and when it boots into Windows press and hold the power button until the laptop shuts down. Do this 3 times in a row i.e. Start > boot > force shutdown > start > boot > force shutdown > start etc
On the 3rd attempt it should boot into the WRE menus.
If it does then go to Troubleshooting > Advanced > Startup repair and follow the prompts. Do not select Reset this PC because if you select the wrong option after this you can erase all your data as Windows will be reinstalled
b). If for whatever reason you can’t get into the WRE menus this way create a Win 10 recovery USB drive. To do this, all you need is access to any known working Win 10 computer, an empty 8GB USB flashdrive and 40-60 minutes of time.
In the host computer go to Control Panel > Recovery > create a recovery drive and follow the prompts.
When you have the USB recovery drive, start the laptop and get into BIOS (press F2) and enable the Legacy USB setting (or perhaps CSM) and also alter the boot priority to USB first boot option. Insert the USB into the USB port of the laptop, Save the changes and exit BIOS.
This will restart the laptop and it should boot into the WRE menus from the USB drive. See above for what to do once you’re in the WRE menus
Punteggio 1
Aggiungi la tua risposta
gforsyth sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 3
Ultimi 30 giorni: 22
Tutti i Tempi: 329
