Salta al contenuto principale
Il sistema operativo Apple per i suoi computer desktop e portatili Mac.
Office 2011 not opening.
Hi, I was wondering if you could help, everytime i open Word, Powerpoint, or excel for mac (the rest work fine), It comes up with "The Office for mac installation did not complete successfully because there was a problem with the installer"
Immagine
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione prescelta
The problem is solved, I downloaded a fresh copy of office
Punteggio 0
The older versions of Office installer have a certificate within them to make sure they are not tampered with. This certificate has an expiration date which on the 2011 version has expired. I would recommend you get a newer version that works on your given OS-X/macOS or you’ll need to alter your systems date back to 2012/13 so the installer thinks its back within the certificates window.
I would also make sure you are running the highest version of OS-X/macOS your system supports as well to be safe.
For reference: If you've got an old macOS install image, it will probably stop working today
Punteggio 0
Aggiungi la tua risposta
macbookiphone sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 2
Ultimi 30 giorni: 10
Tutti i Tempi: 455
