Salta al contenuto principale
HP doesn't accept input from HDMI/DisplayPort Cable, but does from...
I have an HP ProDisplay P202.
I can connect my MacBook A with USB-C using <USB-C to DisplayPort cable> and use the monitor, but the following doesn’t work:
Macbook A to <USB-C Vava HUB> then <HDMI to DisplayPort Cable #1>
Macbook A to <USB-C Vava HUB> then <HDMI to DisplayPort Cable #2>
Apple TV with HDMI using <HDMI to DisplayPort Cable #1 or #2>
Macbook B with HDMI using <HDMI to DisplayPort Cable #1 or #2>
I can’t figure out what the issue is since monitor works with one cable, but not HDMI cable - is there something about HDMI to DisplayPort that prevents it from working correctly?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
From what you have described I would say it is probably the HDMI cable that is the problem. Have you tested it on another system? Just curious, why would you want the HDMI cable over Display Port? It is like beer and champagne.
Punteggio 1
Preparati per le riparazioni future
Aggiungi la tua risposta
Melvin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 260
