Salta al contenuto principale
Il Google Pixelbook Go è un Chromebook di fascia alta prodotto da Google, caratterizzato da un resistente design a conchiglia in magnesio dallo stile minimalista. Rilasciato nel 2019. Numero di modello: GA00521-US.
Re-insert clamshell pin into hinge
Immagine
One end of the hinge on the Google Pixelbook Go has slipped out of place. I do not know how to reinsert it. The two pieces of the clamshell do not feel flexible enough to bend and allow the pin to slip back into the hinge.
Questa è una buona domanda?
Punteggio 4
Aggiungi un commento
4 Risposte
Curious what you ended up doing here. Your issue (and mine) is that the hinge itself is broken. This is caused my the screws loosening causing a torsional flex in the hinge when then snaps it.
The screws loosen over time due to hinges being too tight.
Google isn’t supporting the devices and there’s no way to get replacement parts.
Punteggio 0
2 Commenti:
TL;DR Don't buy Pixelbooks.
I returned the broken Pixelbook to the seller and got back 80% of the purchase price. The money I got back was enough to buy two Lenovo Chromebooks w/ 8GB and touch screens.
da
I have the same Pixelbook AND the exact same issue. I have another problem as well, when the right hinge is lowered, the display goes black, everything still works, the device isn't turned off, I believe it might be a severed display cable
da
It seems that the hinge is snapped from the image. Could have happened when the LCD is accidentally pushed exceeding the limit. Can be fixed by removing the back cover and swap out the damaged hinge.
Punteggio 0
I was able to buy a hinge on eBay (at outrageous price for such a small element) and replace it, otherwise you can replace the whole unit for $$$.
Punteggio 0
@piotrkaminsk163 How did you replace it?
Punteggio 0
Aggiungi la tua risposta
Aaron Hoffer sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 37
Tutti i Tempi: 1,620
