Salta al contenuto principale
Vodafone è una società di telecomunicazioni globale con sede a Londra, in Inghilterra. L'azienda produce telefoni cellulari oltre a gestire reti cellulari.
How do I replace the screen?
My screen is cracked on my phone, and I would like to repair it. Is it possible to do this myself? I have limited experience of doing such things but I am quite careful and patient with delicate things, and would rather not get a new phone if I can repair it. Thanks for your help!
Questa è una buona domanda?
Punteggio 0
1 Commento
Hi Virginia,
If you want help, you must state your exact make and model of phone.
Otherwise no one will be able to help you. They are all different.
da Condividi
Aggiungi un commento
2 Risposte
Risposta più utile
Depending on the phone you have you can probably even look it up on this website for your phone model/ what your phone is called (persay LG stylo 6) and there should be a screen replacement tutorial for you, so yes if you have all of the right tools you can fix your screen yourself (you may have to order a new screen and the tools if you dont already have these items you need).
Punteggio 2
Punteggio 0
1 Commento:
See the comment on the original question, which your answer is a word for word copy. Assuming you have the same issue and aren't just a troll, we still need to know what model of phone you have.
If you don't provide that sort of information, I'll archive your question as unanswerable.
da Condividi
Aggiungi la tua risposta
Virginia Vargo sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 31
Tutti i Tempi: 585
