Salta al contenuto principale
The Asus VivoBook Q302LA-BHI3T09 is a convertible touchscreen laptop. It weighs 3.8 lbs and has the dimensions of 8.9 x 13 x 0.9 inches with a 13.3 inch screen size. It contains a 4th Generation Intel Core i3 and 500 GB hard drive, webcam, microphone, and card reader.
How is the processor cooling
How is the processor cooling if there is nothing over it to take the heat away? There is nothing connecting the processor with the fan. I have attached a picture of the internal of my laptop. And what can be done to better its cooling? the Name of the model is Asus X412FA, i3 10gen CPU.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @sds1013 ,
There is no picture with your question.
Here’s how to add pictures to your question in ifixit Aggiungere immagini ad una domanda
In the image in Step.6 of the Asus VivoBook Q302LA-BHI3T09 Display Replacement guide, (laptop model you selected), you can see the heat sink covering the CPU. It is part of the heatsink/fan assembly (supplier example only to show part and cost)
If you have a different model just search online for Asus (insert full model number) heatsink/fan assembly to find suppliers that suit you.
Immagine iFixit
Guida
Difficoltà:
Molto facile
2 - 5 minutes
Immagine Asus VivoBook Q302LA-BHI3T09 Display
Guida
Difficoltà:
Moderato
15 minutes
Punteggio 2
Aggiungi la tua risposta
Soumyadeep Saha sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 145
