Salta al contenuto principale
Asus VivoBook Q302LA-BHI3T09 Display Replacement
Cosa ti serve
  1. Asus VivoBook Q302LA-BHI3T09 Display Replacement, Display: passo 1, immagine 1 di 2 Asus VivoBook Q302LA-BHI3T09 Display Replacement, Display: passo 1, immagine 2 di 2
    • Before doing a repair or replacement make sure the laptop is fully shut off.
    • Using the JIS #0 Screwdriver, unscrew the ten 10 mm screws that hold the back casing in place
  2. Asus VivoBook Q302LA-BHI3T09 Display Replacement: passo 2, immagine 1 di 2 Asus VivoBook Q302LA-BHI3T09 Display Replacement: passo 2, immagine 2 di 2
    • Insert the flat edge of the opening tool in between the back casing to remove the back casing.
    • Try to use the opening tool at multiple points. Lifting the back casing abruptly could damage the laptop.
  3. Asus VivoBook Q302LA-BHI3T09 Display Replacement: passo 3, immagine 1 di 2 Asus VivoBook Q302LA-BHI3T09 Display Replacement: passo 3, immagine 2 di 2
    • Using the JIS #0 Screwdriver, remove the five 3.0 mm screws that hold down the hard drive casing.
  4. Asus VivoBook Q302LA-BHI3T09 Display Replacement: passo 4, immagine 1 di 3 Asus VivoBook Q302LA-BHI3T09 Display Replacement: passo 4, immagine 2 di 3 Asus VivoBook Q302LA-BHI3T09 Display Replacement: passo 4, immagine 3 di 3
    • Lift the hard drive up and remove the power supply cable connected to it.
    • Make sure to pull on the plastic head and not the actual wires to prevent tearing them.
  5. Asus VivoBook Q302LA-BHI3T09 Display Replacement: passo 5, immagine 1 di 2 Asus VivoBook Q302LA-BHI3T09 Display Replacement: passo 5, immagine 2 di 2
    • Disconnect the white and black wires attached to the Wi-Fi chip.
  6. Asus VivoBook Q302LA-BHI3T09 Display Replacement: passo 6, immagine 1 di 3 Asus VivoBook Q302LA-BHI3T09 Display Replacement: passo 6, immagine 2 di 3 Asus VivoBook Q302LA-BHI3T09 Display Replacement: passo 6, immagine 3 di 3
    • Remove the two adapters connecting the display to the motherboard by pulling the black plastic straps directly upwards.
  7. Asus VivoBook Q302LA-BHI3T09 Display Replacement: passo 7, immagine 1 di 3 Asus VivoBook Q302LA-BHI3T09 Display Replacement: passo 7, immagine 2 di 3 Asus VivoBook Q302LA-BHI3T09 Display Replacement: passo 7, immagine 3 di 3
    • Use the JIS #0 screwdriver to remove the five 5.0 mm screws connecting the display to the rest of the laptop.
Conclusione
Deric Wright
Membro da: 02/14/18
636 Reputazione
3 Guide realizzate
USF Tampa, Team S5-G5, Eyestone Spring 2018 Membro di USF Tampa, Team S5-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S5G5
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 277
