Salta al contenuto principale
Il Dell Inspiron 14R-5437 è un portatile sostitutivo del computer fisso in grado di durare a lungo. Con una batteria sostitutiva a 6 celle rimovibile e un processore Intel Core i3 di quarta generazione a basso consumo, l'Inspiron 14R-5437 ha la potenza necessaria per funzionare per quasi dieci ore.
Wrired Upload Speed Issues
Hi,
I have issue with low download speeds. I have 40Mbit download current speed, my customer is just donwloading at about 4Mbit speed however. On the opposite side, transfer speed is pushed to the limit. Utilizing Transmission customer. I have 25% of the record downloaded and customer says 100% accessibility, so there ought to be no motivation to not go max throttle. I have set open port and made each setting to make it quick, added not many public trackers. There is a lot of friends, which have all the information, yet customer is nearly not downloading from them. It is downloading from others all things considered.
Proportion is going up to 2.0. Where could be the issue?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Please kindly check out these methods for a possible fix.
https://superuser.com/questions/1233477/...
Punteggio 0
Aggiungi la tua risposta
KyleFoleyk sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 7
Tutti i Tempi: 330
