Salta al contenuto principale
Rilasciata nel 2013, identificabile dal numero di modello PS 5530. Stampante, scanner e fotocopiatrice all-in-one. Dispone inoltre di funzionalità web e wireless.
Power AC Adapter search
Hello all…Please can someone tell me where do i buy the AC power Adapter that is shown in your repair videos for the HP 5530-e all in one showing that the Ac Adapter can be removed from under the left hand side of the printer casing , and to change when it’s not working ?..look forward to your replies .
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi @ericthevike66,
Not sure if it is the same for a HP Envy 5530e but looking at this image in the ifixit Sostituzione alimentatore HP ENVY 5530 guide, the model number for the power supply is A9T80-60008.
Immagine
(click on image to enlarge for better viewing)
When searching online using the model number only, there are results for suppliers. Here is just one to give you an idea of the cost.
If the model number of the power supply is different for your particular model then search online using its’ model number to hopefully find suppliers that suit you.
Punteggio 1
1 Commento:
Hello Jayeff…thanking you so much..have used the info to order my Power AC..Thanks a million.
da
Aggiungi la tua risposta
Eric Fielding sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 17
Tutti i Tempi: 277
