Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
Apple bootloop and battery issue
I had an issue with my screen, and apparently seems that’s causing the bootloop. I discovered yesterday that If I press the screen with a little force, the bootloop temporarily disappears and boots normally.
The battery is another issue which I can’t understand, according to apple settings it said that my battery health is 62%, however, if I disconnect it from the charger, it immediately turns off.
What can be causing these issues? Bad cable placing? Need to replace battery ?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Risposta più utile
If your battery health is at 62% I am amazed it even tries to boot. Replace the battery and it will boot without any problem.
Punteggio 2
Try downloading a iPhone diagnostic tool on a PC and see if anything shows up. Such as any battery problems, or if you can have the genius bar look at it.
Punteggio 0
Given the age of the device, I would say that this phone needs a new battery. This may help solve a lot of the issues you are having with the phone.
Punteggio 0
Aggiungi la tua risposta
noteinstein sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 3
Ultimi 30 giorni: 13
Tutti i Tempi: 271
