Salta al contenuto principale
Modello US998U. Si può identificare dal sensore per le impronte digitali/pulsante di blocco posteriore, dalla memoria da 128 GB e dalla doppia fotocamera posteriore grandangolare. Rilasciato nell'ottobre 2017.
Incoming Call Screen Duplicate
My incoming call screen shows then a second later another one pops that I can't access. Cleared permission on all apps and that helped for a few hours but it came back.
Immagine
Questa è una buona domanda?
Punteggio 0
2 Commenti
Hi,
Is it always from the same number?
da Condividi
No all numbers
da Condividi
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi,
Try wiping the cache partition and check if that resolves the problem.
If still no good, try using the phone in safe mode and check if the problem is still there.
If not, then a downloaded app is the cause of the problem. You will need to uninstall each downloaded app, one by one and test the phone in normal mode, between each uninstall to see if the phone works OK. When it does the last downloaded app that was uninstalled was the culprit.
Punteggio 1
1 Commento:
Thanks seems robokiller was the problem
da Condividi
Aggiungi la tua risposta
monte mason sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 16
Tutti i Tempi: 394
