How do you remove this kind of Laptop LCD connector
Guys I have a Asus Vivobook X411UN and I'm trying to replace the LCD. But the problem is I don't know how to remove laptop LCD connector pin.
Questa è una buona domanda?
Don't know the answer so hopefully someone else will.
Perhaps if no one else answers, since you have to replace the LCD screen then maybe just disconnect the cable from the LCD screen end only and connect the new screen to it.
Looking at the replacement cable it seems that it can be removed from the LCD and is not permanently connected to the display assembly as some are.
Perhaps it may be easier to get at.
The part number for the cable is 14005-02440100 found on this website
Thanks for the picture. There are two shoulders on the cable connector that provide a place to push on to remove the connector. I'm assuming it's similar to the one used on the S400C in that being taped down it almost certainly doesn't have any kind of latch.
Take a couple of spudgers and place one at each point of the arrow and push them both evenly in the direction of the arrows. It should simply slide out - it may take a little bit of force; I know the S400C does.
Just pull the sticker to the point shown in the image,
Then pull out the lego type connecter little by little, by pulling left and right side of the connecter little by
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 30
Tutti i Tempi: 2,496
2 Commenti
Hi,
Post a close up image of the connector
Aggiungere immagini ad una domanda
da jayeff
Done posting
da razankasglen
