Salta al contenuto principale
Console per videogiochi prodotta da Sony Computer Entertainment; la PlayStation 4 Slim (serie CUH-2000) è un modello sostitutivo più sottile della PS4 originale. Annunciata il 7 settembre 2016.
PS4 wont install update
I swapped the hard drive on my ps4 slim and attempted to download the newest software update. I am aware there are two versions and the larger file is the one im using. I followed the exact guidelines on how to setup the usb, with the right directories.
I have tried 2 different hard drives, 3 different usb drives and even downloaded it from different computers and different browsers.
I have tried both usb ports on the console aswell.
Nothing has worked yet.
when I try to reinitialize I get two errors in separate occasions.
SU-30625-6
SU-30645-8
If anybody knows how to fix this please help!
Questa è una buona domanda?
Punteggio 1
2 Commenti
how to fix update issues without changing your hard drive
da
Can you please share the error code you are seeing? I would try a offline update first with the USB. Does that work???
da
Aggiungi un commento
1 Risposta
Risposta più utile
Does the blu-ray drive take discs in fine and able to read discs before doing the update?
Punteggio 1
3 Commenti:
The old hard drive was faulty, I cant even get the console to go past safe mode. So I cant really check if it takes discs
da
Is the replacement hard drive a new one or a second hand one?
da
tried both new and second hand
da
Aggiungi la tua risposta
Nico sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 17
Tutti i Tempi: 293
