Salta al contenuto principale
Rilasciato a metà 2018. Laptop con CPU i5 di ottava generazione, 8 GB di RAM e SSD M.2 da 128 GB.
How to replace the hdd to ssd?
My model ce0001ne, it comes with 1 tb HDD, I want to replace it with SSD, how ?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi @alimohd ,
Here’s the maintenance and service guide for the laptop, taken from this webpage.
Go to p.63 to view the necessary pre-requisite steps and then the procedure to remove the HDD so that it can be replaced with a SSD
Here’s a link to just one supplier of SSDs. It is only to show what SATA SSD are compatible with your model and how much they might cost. There are other suppliers online that may suit you better.
Usually there are instructions that come with the SSD that detail how to transfer the data from your HDD to the SSD
Punteggio 1
1 Commento:
Thank you so Much!
da
Aggiungi la tua risposta
Ali Mohd sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 38
Tutti i Tempi: 1,488
