Salta al contenuto principale
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
382 Domande Visualizza tutte
Replace Logic board with Late 2009 logic board?
I bought this from a govt auction. They pulled the hard drive out, but in that process they broke the display adapter on the logic board. Can I replace this board with a board from Late 2009?
Questa è una buona domanda?
Punteggio 0
5 Commenti
Please post a few pics of the damage Aggiungere immagini ad una domanda so we can see what you need.
da
Hi Dan, I just uploaded a couple of pictures.
da
Yup it is possible
if you find my answer useful please click accept as a solution.
da
@imacman123 - So how you you fix this?
Saying its possible is not an answer!
da
I meant it is possible to use a 2009 replacement logic board on an iMac 2009 sorry for misunderstanding.
da
Aggiungi un commento
3 Risposte
Risposta Più Utile
I’d see if I could disconnect the connector body which was pulled off with the cable from display cable, then connect it to the logic board and secure it with Kapton tape then connect the cable back to the display.
Punteggio 3
4 Commenti:
@mayer - Yes, threading the plastic shell back is a possible solution!
da
So, the logic board connection would be the new "permanent" connection?
da
prabs That's the idea. Straighten those pins up some before doing it first.
da
Thanks. I will give it a shot or try what Dan suggested.
da
Here’s a vid showing the steps to re-tin the pads after desoldering the pins from them iMac 21,5" & 27" LVDS Display connector repair and here is the connector LCD Display LVDS Cable Connector (30-pin)
You may want to find someone with the needed tools and skills to put a new connector on. This would be the best solution if you can’t get the pins re-inserted into the shell.
Punteggio 2
1 Commento:
Thanks. I will ask if my buddy can give it a shot or try what mayer suggested.
da
The best solution would be to solder a new socket on the board. Try to fit the broken one is risky cause you could short pins and damage the display and (or) the logic board. There's 50v passing thru the socket to the display cable.
Punteggio 1
1 Commento:
Long time, no see
da
Aggiungi la tua risposta
prabs77 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 108
