Salta al contenuto principale
Floor lamps are lights that sit on the floor. They are not table lamps, which are designed to sit on tables. Floor lamps are usually taller than table lamps.
20 Domande Visualizza tutte
Does anyone know how to fix this?
Hi! Does anyone know how to fix this lamp? It has three sockets inside and is touch sensitive. You can touch it up to three times to turn each bulb on. I’m not sure if I accidentally put 60 watt bulbs in instead of 40 watts and burnt it out. It just won’t turn on anymore.
Here is the URL with the specs: https://www.officedepot.com/a/products/7...
Questa è una buona domanda?
Punteggio 0
2 Commenti
Once fixed, use LED bulb. Low wattage same light.
da
FYI: if the touch lamp is the dimming type, need to ensure you get DIMMABLE LED lamps. It sounds like the particular lamp might be an unusual design, that turns each of the 3 lamps on, to have 1, 2 or 3 on, then all off. If so, then NON-Dimmable ones MIGHT work OK.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
The control board for these is typically based around a TT6061 touch/timer/control chip, and a BT134 or BT136 Triac to turn the lights on and off or dim at any one of 3 levels. I suspect you will have the lower rated BT134 device, as the bulbs are limited to 40 watts. What often breaks the Triac, is the high current “plasma arc” that happens inside a bulb when the tungsten filament fails. I have found over the years of repairing these, that the best bulbs to use are the Halogen types, as the little Halogen lamp cartridge (28w or 42 watt) that is inside the outer glass (decorative) envelope, has a gas mixture under a slight pressure, so when the filament fails, there is usually NO arc at all, to break the electronics. You CAN get the Triac, and replace it, but sometimes the IC chip get broken too, and they are difficult to get, and to replace, unless you are good with de-soldering and re-soldering techniques. It is often easier to replace the touch module, if you can get one. Check on EBAY or a good electronics shop.
Punteggio 4
Hi @kimberlylove ,
The control circuit most probably has been damaged as the lamp specifications (click on Product details), state maximum bulb wattage is 40W.
You would have to check the control board for any obvious damage to the components e.g. burnt out or heat stressed etc.
Post some close up images of the board, showing the damage or even if you’re not sure if there is or not. Here’s how to do this Aggiungere immagini ad una domanda
Punteggio 1
Aggiungi la tua risposta
Kimberly sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 374
