Salta al contenuto principale
Il Mac Pro Early 2009, noto anche come Mac Pro 4,1, ha introdotto l'architettura Nehalem di Intel nella linea di computer desktop professionali Apple nel marzo 2009. Il Mac Pro 5,1 utilizzava lo stesso design interno ma ha ricevuto ulteriori aggiornamenti della CPU nel 2010 e nel 2012.
Upgrading Mac Pro from Single CPU to Dual CPU
I have a very specific question about upgrading a 2009 Mac Pro from a single CPU to a dual CPU.
I want to do this upgrade a little bit at a time, since the parts are kind of expensive. My single processor is a 6-core 3.33. If I start by replacing my processor tray with a dual tray, can I run the dual tray with only one CPU installed? For as long as it takes me to find/save up for the smaller dual heat sinks and a second matching 6-core CPU?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta più utile
Yes, but you should be able to get the whole tray with heat sinks and minimal Cpus for about $200. I’d wait till I could pop for that much and then go for your Intel Xeon X5690 3.46GHz SLBVX 6 Core CPU X58 LGA1366 Processors.
Remember that the newer trays don’t work with the 2009. Also the CPUs on the 2009 need to be de-lided
Punteggio 1
1 Commento:
Hola,
¿Y si el hubiera actualización y fuese un 2009 con 5.1? ¿Podria poner la bandera del 2010?
da
hi, no, one single core will drive teh smc ro run at full speed, vent will run at full speed, you need 2 cores inside
Punteggio 0
Aggiungi la tua risposta
John M sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 10
Tutti i Tempi: 1,868
