Salta al contenuto principale
La terza generazione della serie di phablet Samsung Galaxy Note rilasciata il 25 settembre 2013. Identificabile dal numero di modello N9005.
Why is my screen blank?
why is the screen blank when the phone is on?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hi,
Has the phone been dropped or gotten wet at all?
Try shining a torch at an angle close to the screen to see if you can detect an image at all when the phone is on.
If you can see an image, (or even if you can’t) the phone will have to be opened to further diagnose the problem to isolate where exactly it might be, in the LCD display, the LCD display flex cable connection to the systemboard or the systemboard.
As a DIY repair all you can do is to initially check if the LCD screen flex cable connection to the systemboard is secure and if so then temporarily replace the screen assembly to see if it works OK or not .
Here’s a link to the ifixit Sostituzione gruppo schermo Samsung Galaxy Note 3 guide, which may be of some help.
Replacement display assemblies are available from ifixit (limited stock - click on the parts link in the guide to check what may be available for your particular model) or online. Just search for Samsung Galaxy Note 3 display assembly to get results for suppliers of the part.
Punteggio 0
Aggiungi la tua risposta
bigjohnson6767 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 22
Tutti i Tempi: 221
