Salta al contenuto principale
The Corsair Void Pro RGB is an optimal wireless headphone compatible with most media devices. This set features both dual speakers and a microphone.
Battery Replacement with 2 pin
I bought a li po battery with only 2 pins on it instead of 3. Can I still use this? Based on my research i can use a 10k fixed resistor. Anyone know how I can do that? Any help will be much appreciated.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Hi!
Yes you can probably get it working with a 2 pins battery, but I wouldn’t do it.
Just return the battery and get yourself the correct one that is supposed to work with your Corsair Void Pro RGB, it will spare you some trouble too.
Punteggio 1
2 Commenti:
Thank you for the input but your suggestion is not possible for me due to logistics on acquiring the battery
da
Okay. Do you have a picture of the battery you bought and a picture of the original battery ? Thanks in advance!
da
Aggiungi la tua risposta
Merlin Meliodas sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 27
Tutti i Tempi: 402
