Salta al contenuto principale
L'Asus K53E-BBR3 è un elegante notebook metallico da 15,6 pollici per l'uso quotidiano, uscito nel 2011.
DC power jack loose
Can anyone helpme, this just occured today. When i was charging my laptop it suddenly not charging so i push and it work only if i pushed it. After searching on the internet it says that my laptop dc jack has come loose, can anyone help what should i do with this.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
If the power jack has come loose, you need a soldering iron to reattach it to the motherboard. It needs to be a good one, the cheap ones don’t get a good enough temperature to get rid of the old solder. If the power jack itself is damaged, you can usually buy a replacement power jack online with the correct make and model number of the laptop.
If you’re not that good with a soldering iron, or don’t have one, then you can disassemble the laptop and take the motherboard and power jack to a computer repair shop and they should be able to do it. Most of the time is taken up by the disassembly as it can be a bit persnickety, but instructions are available online and on YouYube for many different models.
Punteggio 1
Aggiungi la tua risposta
Bodybody sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 10
Tutti i Tempi: 819
