Salta al contenuto principale
Guide per riparare e disassemblare telefoni di ogni marca e compagnia telefonica, inclusi iPhone e Samsung Galaxy. Procurati tutto quello che ti serve per riparare il tuo telefono da solo.
Why isn't it working?
So I accidently got water in my phone ,then I left it in a bag of rice over night then when I turned it on the next day the screen stayed blank and then it started making ringtone noises and it still won't work…what do I do?
Questa è una buona domanda?
Punteggio 0
1 Commento:
Rice is for eating, not for drying phones out
da
Aggiungi un commento
2 Risposte
One day is not long enough for the water to dry if your phone was in a bag. If you can, try removing the phone’s battery and laying everything in front of a fan so it can dry a bit faster.
Punteggio 0
1 Commento:
Thank you I'll try it x
da
depending on your phone Rice may not actually do anything at all.
phones these days are compact tightly designed machines and for rice to work it has to come into contact with the water more or less. the water isn’t able to escape towards the rice so it stays in the device.
first step is to remove the battery and clean the motherboard. isopropyl alcohol should be enough if not much corrosion has occurred. when that’s done based on your description you most likely need to replace the screen assembly. of course it’s also possible the water did permanent damage to the display circuit which would require a specialist to fix.
if you give us the model # of your phone it could help us help you as well
Punteggio 0
Aggiungi la tua risposta
Ashia Begum sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 52
