Salta al contenuto principale
Rilasciato il 16 settembre 2016. Modello 1660, 1778. Disponibile come GSM o CDMA / 32, 128 o 256 GB / Rose gold, gold, silver, black e jet black.
2264 Domande Visualizza tutte
iPhone 7 water damage not turn on
Hello. I have a problem with the flooded iPhone 7, it had a short circuit of 0.350a I was able to remove it now it is 0.000a after turning on nothing happens and stands at 0.060-0.080a. Have any ideas?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
you need to clean it using isopropyl alcohol. that will involve completely disassembling it.
Electronics Water Damage
Sostituzione case posteriore iPhone 7 (you do not have to replace the rear case, but this guide will go over complete disassembly.
Punteggio 1
2 Commenti:
pcb I already cleaned in an ultrasonic cleaner. A few capacitors fell in and there is no pmbb layout because it was short
da
@dxwxd ah, apologies. This is probably beyond my scope. @refectio could probably help here.
da
halo cześć,
0,06A przy starcie wskazuje na niski bilans energetyczny. W takich przypadkach warto przestudiować linie główne zasilania. W większości przypadków, jeśli ich parametry mieszczą się w normie szukałbym “korka” za PMU. Sprawdź porty LDO z MPU i CPU razem z liniami SOC. Niewiele dalej, bo od 0.09 zaczynają się spięcia pod procesorem, spowodowane przegrzaniem 7-ki przy zdejmowaniu shield’ów.
pozdrawiam,
Punteggio 0
Aggiungi la tua risposta
Dawid Wojtyła sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 102
