Salta al contenuto principale
La Sony Cyber-shot DSC-W830 è una fotocamera da 20,1 megapixel progettata per acquisire immagini fisse e registrare video fino a 720 pixel.
SD card write protected
my SD card is write protected so I can’t take pictures. It happens with every SD card I use. The physical write protection is turned off, I can’t reformat the card because I just get a pop up that says the SD card is write-protected.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Hi,
Can you format the SD Card in a computer and then try it in the camera?
If it still fails, it appears as though the contact in the SD Card reader in the camera, that detects the position of the lock switch on the SD Card may be bent or stuck, indicating the card is locked when it isn't.
You’ll probably have to open the camera to access the SD card reader and most probably have to replace it.
Here’s a link to the ifixit Sostituzione scheda madre Sony Cybershot DSC-W830 guide which may be of some help in gaining access to the card reader.
If this seems too daunting, contact a reputable, professional camera repair service and ask for a quote
Punteggio 2
1 Commento:
I put the card in the computer, but it still failed in the camera. So I will follow up on this solution. Thanks!
da
Aggiungi la tua risposta
tagarrison sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 26
Tutti i Tempi: 751
