What screwdriver do I need
Can someone link me a screwdriver from the ifixit store that can be used to open up a joycon
Questa è una buona domanda?
@andrewifix you need a Y00 bit for the backplate iFixit Precision 4 mm Screwdriver Bit Even better if you get the kit so you have all drivers for most common repairs Mako Driver Kit - 64 Precision Bits
Prodotto
$39.95
Prodotto
$2.99
For the inside of the Joy-Con, you will also need a Phillips #00: https://eustore.ifixit.com/products/phil...
@oldturkey03 gave you some good options, and you hopefully fixed your controller by now, but if you only need a fixed blade screwdriver to open your Joy-Con or Switch, iFixit sells a Tri-point* Y00 Precision Screwdriver
*AKA a Tri-wing screwdriver. It is different from an actual "Tri-wing" Screwdriver. If you are opening a Switch Joy-Con, the screwdriver tip should resemble a Mercedes logo and not a shuriken. These nuances between screw types and more are in this Nintendo Switch screwdriver wiki resource.
Ultime 24 ore: 6
Ultimi 7 giorni: 57
Ultimi 30 giorni: 209
Tutti i Tempi: 51,390
