Salta al contenuto principale
Annunciato il 16 ottobre 2014, identificabile dal numero di modello A1347 e EMC 2840.
Can I replace HD?
Recently, I purchased a Mac Mini 2014 A1347 model. I understand the RAM is soldered to the board and is not upgradeable. My next thought is to replace the HD and/or add a second HD.
Currently, I am running Mojave on this computer and haven’t had any problems. I was thinking of at least installing a second drive but I am not sure if I need to buy a HD tray or HD cable.
Update (05/20/2019)
If I didn’t want to replace the main HD, can I add a second drive? If so, do I buy an HD tray or HD cable?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
What is your current drive status?
Sostituzione SSD Mac Mini fine 2014
Sostituzione hard drive Mac Mini, versione fine 2014
UPDATE
As you can see from the guides, adding an SSD is a 15 minute job while replacing the hard drive is a two hour job. Go here to select the size of drive to fit your needs:
OWC Aura Pro X2 SSD
Immagine Replace or upgrade the PCIe solid-state drive in a variety of Macs.
Prodotto
OWC Aura Pro X2 SSD
$239.99
Immagine Mac mini Late 2014 SSD
Guida
Difficoltà:
Moderato
15 minutes
Immagine Mac mini Late 2014 Hard drive
Guida
Difficoltà:
Moderato
30 minutes - 2 hours
Punteggio 2
2 Commenti:
I am not sure what you are asking "current drive status". The computer came with the existing HD. I think it is SATA but I am not sure. The computer is working fine.
da
If you have a hard drive model then you can add the blade SSD. If you add the SSD you can make it the boot drive speeding up the boot and running the apps.
Otherwise your only option is replacing the HD with a larger drive if that's what you want.
da
About your question. This unit is very much upgradeable when it comes to adding bigger or better hard drive. Only issue is its not as easy as just popping out a cover and pulling out the drive. To answer your exact question, this model comes with a regular mechanical drive and can be upgraded to a bigger size or even an SSD. You wont need any adapters or cables.
Punteggio 0
2 Commenti:
I understand what you are saying. However without taking it apart, there appears to a spot below the silver plate to add a second drive. Obviously, I need an HD cable or tray to connect it to the board.
da
Adding a second hard drive is not possible. You can only add a blade SSD drive.
da
Aggiungi la tua risposta
jkbmjp sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 204
