Salta al contenuto principale
Il Surface Laptop 2 di Microsoft è stato distribuito nell'ottobre 2018.
Screen is damaged internally
Immagine
Screen doesn’t show physical damage only internal.. How can I fix this?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi,
As you can see, in the upper right corner of the screen there is a crack (circled in red) in the liquid crystal layer of the screen, which is most likely causing the horizontal lines going through the LCD. I would send the the laptop to a repair shop for them to fix it for you because the Surface Laptop is very, very difficult (or maybe even impossible!) to open up with out inflicting lots of damage to both the internal components and outer casing.
Immagine
Punteggio 1
1 Commento:
This kind the issue can not been fixed but replace the whole LCD so far
da Condividi
Aggiungi la tua risposta
Ailyn Gonzalez sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 29
Tutti i Tempi: 1,701
