Salta al contenuto principale
La Wii U è una console videogame prodotta da Nintendo, abbinata a un dispositivo portatile che consente agli utenti di giocare tramite il GamePad. La riparazione della console è semplice, poiché il dispositivo è molto modulare.
Wii U Not starting; Blinking red light
i was recently wanting to play on my Wii u for the first time in a month or so. the light tuns on blue for a second with the fan coming on then blinking red light. it has been opened recently to be cleaned. any ideas
Questa è una buona domanda?
Punteggio 1
1 Commento
J'ai ma Wii U qui affiche un voyant rouge tout en clignotant quand je tante de l'allumer, et le ventilateur à l'arrière de la console ne tourne pas. Que dois je faire?
I have my Wii U flashing a red light while flashing when I try to turn it on, and the fan on the back of the console is not spinning. What should I do?
da
Aggiungi un commento
4 Risposte
Risposta più utile
I know this is an old post, but if you opened up the console and removed the disc drive, be sure to plug the flex cable in the same way it was removed. You can swap the cable around and it will fit, however you'll get the blinking red light when you try and turn it on.
Punteggio 4
3 Commenti:
thank you!!! :)))
da
Worked wonders, always try this!
da
Yo estoy en la misma situación pero yo la desarme porque no me quería agarrar la sd pero cuando la desarme me pasó lo mismo pero ya le hice de todo y no encuentro la falla
da
Make sure plugs are all plugged in. Did u have a game in it? Try to get it out and try again. Or maybe you left it on last time you played which can overheat it
Punteggio 0
https://www.bing.com/search?q=How%20to%2...
Punteggio 0
Nothing is helping my Wii U it is always just a blinking red light I don’t know what to do anymore I try cleaning it and cooling it down I left it unplugged for over a month came back and still just a blinking red light.
Punteggio 0
Aggiungi la tua risposta
jake sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 37
Tutti i Tempi: 3,115
