Salta al contenuto principale
Il ThinkPad X200 è stato rilasciato nel 2008. Sfrutta le nuove tecnologie del modello X300, tra cui le opzioni di unità a stato solido (SSD), fotocamera integrata opzionale, display widescreen da 12,1", WWAN 3G opzionale, una nuova batteria a 9 celle per un'autonomia prolungata fino a 9,8 ore, un peso ridotto fino a 1,34 kg (2,95 lb) e CPU fino a Intel Core 2 Duo da 2,66 GHz.
Ethernet not detecting network
Hi,
Swapped my HDD for an SSD and installed a fresh copy of Win 10.
Naturally I had some driver issues, but try as I might, My LAN connection will state “Unidentified Network” and will not connect to the internet.
Wifi is working well and connects to the internet.
Tried the driver on: https://support.lenovo.com/il/en/downloa...
Adapter is detected as “Intel 82567LM Gigabit Network”
Laptop full model is: 7454-2HU
Thanks in advance
Questa è una buona domanda?
Punteggio 0
9 Commenti:
Hi @goom
Had you tried updating the laptop BIOS?
Had you tried using another LAN cable?
Had you tried connecting to another known working LAN port?
da
Hi @goom ,
What is the status of the LAN adapter in Device Manager?
Go to Device Manager (right click Windows Start button, left side of Taskbar, find Device Manager link) > Network Adapters > right click LAN adapter entry > Properties > General Tab > Device Status.
Have you tried using the Troubleshooting program in Win 10?
Go to Control panel (click on Windows Start button left side of Taskbar) type Control Panel in search box > select Control Panel desktop app that appears in pop up window > Troubleshooting > Network and Internet > Connect to the internet and follow the prompts
da
Will try BIOS.
Have tried different cables and routers.
LAN device is working and up to date.
Troubleshooter can't understand why I'm not getting an IP.
da
Did you check the antenna wires to the wireless adapter? The connectors tend to be easy to take off but sometimes very hard to connect.
da
Wirless adapter works flawlessly.
da
Mostra 4 altri commenti
Aggiungi un commento
1 Risposta
I suspect the wrong driver might be installed. I’d suggest finding the hardware ID of the wireless card and searching google with it to make sure you have the correct model of your wireless card.
To find the Hardware ID go to device manager—>device properties—> details tab—> and then choose “hardware id” from the drop down list. Copy one of the strings listed and paste it into google and see what comes up.
Punteggio 0
Aggiungi la tua risposta
Goom sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 12
Tutti i Tempi: 1,800
