Salta al contenuto principale
Rilasciato nel giugno 2006, il Dell Inspiron 530 è il primo desktop della linea di prodotti Inspiron.
PC Will not boot!
Power on, amber light on, fan running as start-up. Amber light gave one beep. Replaced motherboard with new, replaced battery (3.3VDC) . Same symptom. Replaced PSU with upgraded new 400V. Checked with all outgoing cables unplugged. Checked RAM and hard drive on a working 530 and all functions as they should. Replaced CPU with new upgrade. Replaced power switch with new, Same symptom with amber light, no beeps, fans run as start up. Reset the BIOS, amber light on power button, no fan until power button is pushed. Cannot turn off fans w/power button. Will reset if power is removed from desktop. Now what?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione prescelta
Hi @rocketpyro ,
Did you try a “Power reset” to reset the BIOS to default values and check if it starts OK?
To do this, switch off the PC, remove the power cord from the outlet and also the RTC battery from the motherboard and press and hold the Power button for 30 seconds. Reinsert the RTC battery, connect and switch on the power and try to start the PC.
Since you have tried a new motherboard, (was it a known working motherboard?), a new PSU, a new RTC battery and a new CPU, have you tried the new (or the original) motherboard in lieu of the one you tested the RAM and HDD on to see if it worked there? At least to see if it starts and passes POST and you can get into BIOS anyway.
If the replacement motherboard (or the original) now doesn't work elsewhere either, (your question indicates that you changed the motherboard before changing the PSU), I'm wondering if the old PSU may have somehow damaged the motherboard and subsequently the 2nd motherboard as well or may have only hopefully corrupted the BIOS somehow in both motherboards.
Have you tested the old PSU to make sure that it is OK re the voltages supplied by it? Use the paperclip test and check that all the relevant voltages are within specs.
Punteggio 3
According to the BIOS codes, it means the BIOS is corrupted. But, because it happened with 2 boards, it can be that both are broken. Or something is happening strange with your PC.
Punteggio 1
Aggiungi la tua risposta
James sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 28
Tutti i Tempi: 2,349
