Salta al contenuto principale
Modello A1200 con processore Core 2 Duo da 2,16 o 2,33 GHz
hard drive replacement manual
I have searched the manuals and cannot find one on the hard disk replacement of the EMC 2111 24" intel imac.
I understand that there is one but cannot find it.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Soluzione prescelta
Doesn't appear to be one on the site. But for what it's worth, here's a Macworld article by Kyle Wiens describing the process, though (along with links to other ifixit guides for similar models): http://www.macworld.com/article/145116/2...
The key quote: "The later G5 iMacs and first Intel models are tough: They have nasty retaining clips holding the front bezel in place. Removing the bezel requires a flat pry tool, such as a credit card or ID badge. You also need to completely remove the LCD display and lower EMI shield before you can access the drive. Rating: Difficult"
Punteggio 2
Someone woke this one up after 3years, I thought I might as well update the answer. The guide for the hard drive replacement can be found right here
Punteggio 1
Aggiungi la tua risposta
David Randall sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 14
Tutti i Tempi: 2,634
