Salta al contenuto principale
Un altoparlante portatile Bluetooth 4.0 prodotto da Omaker. L'altoparlante ha un grado di protezione impermeabile IP54, progettato per un uso in ambienti esterni e accidentati. Con un'autonomia della batteria di 12 ore, questo altoparlante è costruito per durare.
How do I replace the speaker?
I am afraid I have blown the speaker as the glue surrounding the mid-piece of the speaker has been decayed likely through overuse. Where may I get a new speaker and how may I replace it? Is this worth the trouble and finances required?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi,
Here’s a link to the ifixit Sostituzione scheda madre Omaker M4 guide.
It is useful as it shows how to open the speaker case so that you can get to the speaker driver.
I cannot find an Omaker replacement for the speaker, but looking at the images in the guide, the information stamped on the speaker shows that it is a 4 Ohm 3 Watt speaker.
If you remove the speaker from its mounts in the case and measure its’ diameter you can use this information in conjunction with the above power specifications to get a suitable replacement.
Here’s a link to just one supplier of 4 Ohm 3 Watt speakers, showing speakers with varying diameters, hopefully one of which will fit inside the case.
You may find other suppliers that suit you better. Just search for (insert diameter of speaker) 4 Ohm 3W speaker to get results
Punteggio 3
Aggiungi la tua risposta
Gavin sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 11
Ultimi 30 giorni: 37
Tutti i Tempi: 492
