Salta al contenuto principale
La stampante e-all-in-one HP Envy 5660 è progettata per stampare, scansionare e copiare, includendo funzionalità come la stampa wireless e un touchscreen a colori. Numero di modello: F8B04A
Paper Jam and gears grinding
The printer won’t print an error screen comes up stating paper jam. I followed all therir instructions and still don’t see a paper jam. As the cartridges move aross it sounds like the gears are grinding on the right side.
Questa è una buona domanda?
Punteggio 0
1 Commento:
I can see a the side of photo paper way in the back. Sometmes it will print sometimes not.
da
Aggiungi un commento
1 Risposta
The reasons for this error can be different every time.
Step 1 : Check thoroughly for even a small piece of paper might be stucked in the printer.
Step 2 : Clean some of the gears inside the printer. After some years they need cleaning .
Step 3 : Some times there is an issue with a small elecromagnet inside the printer that is used to track the paper inside . For this step you might need to give the printer for repair. It still worth the money.
Punteggio 0
Aggiungi la tua risposta
Theresa Schafer sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 14
Tutti i Tempi: 962
