Salta al contenuto principale
Computer portatile Gateway con 4 GB di RAM e 500 GB di HDD. Numero di modello: NE56R49u.
I cannot type numbers
Hello i tried typing numbers, yet its not working,, rather only symbols are working.
I used the set of numbers at the right too yet they didn't work.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi @odimexy ,
Are all the letters OK or are they showing in upper case (capital letters) only?
If they are in upper case (capitals) only check if there is a Shift key stuck in the operated position as this will affect the numbers above the letters on the keyboard as well.
Have you checked that the Number Lock light is operated on the keyboard?
If not press and release the Number Lock key (the number lock light should come on) and then try the numbers on the keypad.
has any liquid been spilled onto the keyboard at all?
Punteggio 2
Aggiungi la tua risposta
Odidi Junior sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 8
Ultimi 30 giorni: 28
Tutti i Tempi: 959
