Salta al contenuto principale
L'LG G Pad X 8.0 è stato rilasciato nel giugno 2016 per la rete T-Mobile con il numero di modello v521. Questo tablet ha uno schermo da 8,0 pollici e un processore octa-core.
Broken Tablet Screen: How To Fix?
My tablet’s screen is basically half broken like fully black with some cracks here and there. I don’t want to upset my father so how should I handle this. As I already stated, half of it is glitched as in broken while the other small spaces barely work.
Questa è una buona domanda?
Punteggio 2
1 Commento
how old are you?
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi,
You need to replace the screen assembly(i.e. LCD screen + digitzer).
Here are links to two videos that show how to replace the screen assembly in your tablet.
screen replacement Pt.1
screen replacement Pt.2
Here’s a link to just one supplier of the replacement part. It is shown just to give you an idea of the cost of the part. There are other suppliers that may suit you better. Just search for LG G pad X 8.0 v521 screen replacement part to get results for suppliers of the part.
It may be advisable to tell your father as most probably he’ll find out anyway. So ‘fess up and get it over and done with. He most probably won’t show it but he may be pleased that you told him before he found out about it, and that you have found out how to fix it. You could even suggest that you could both try and fix it together. ;-)
ifixit also sells the appropriate tools that you may need to use.
Punteggio 2
Aggiungi la tua risposta
Giang Tran sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 2
Ultimi 30 giorni: 25
Tutti i Tempi: 1,568
