Salta al contenuto principale
Informazioni su riparazioni e soluzione problemi per le lavastoviglie a marchio GE.
Is not heating up,
I have a GE model GFD570SGF2WW I replaced the heating element but it still is not heating up, do I need to reset the power to the heating element?
I also see it could be the thermostat, where is that located in my model?
Questa è una buona domanda?
Punteggio 1
7 Commenti
@mmbas What is your water heater's maximum temperature set to? Make sure your dishwasher is set to have only hot water intake. Run the sink next to the dishwasher until the water is very hot before starting a load.
da
Hi @mmbas ,
Could you please verify the model number as the number you posted does not show up anywhere?
da
@jayeff I have a hunch that the OP posted the serial number instead of the model number.
da
Hi @ajcooke01,
You're probably right., although GE GFDS model numbers are used for GE dryers. I know that GFD5 was posted.
Just trying to think outside the square to try and find it ;-)
da
Cool! I learn something from iFixit every day :)
da
Mostra 2 altri commenti
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi @mmbas ,
Looking at the parts list for the dishwasher, there is no mention of a “thermostat” or temperature sensor.
The installation manual states that the incoming water supply temperature is to be between 120F -140F, with a minimum temperature of 120 deg.F
As you say that this is correct then I can only conclude that perhaps the water temperature is controlled by a heater timing circuit in the control board.
Can you use an Ohmmeter to measure the resistance value of both the old heater and the new heater elements? (to measure the new heater, disconnect the power from the dishwasher and then disconnect the heater wiring and just measure across the heater terminals).
If you don’t have an Ohmmeter, adequate DMMs (digital multimeter) which incorporate an Ohmmeter are available from larger hardware stores for approx. <$15
The resistance reading should be ~15-20 Ohms.
If you don’t get a reading at all, regardless of the resistance range selected on the Ohmmeter, then the heater is faulty, i.e. open circuit
If you measure 0 Ohms across the heater terminals then the heater is faulty, i.e. short circuit, but more importantly, if this is the case, it could have damaged the section of the control board that handles the heating function.
Punteggio 3
2 Commenti:
I have the same problem with my GE dishwasher Adora new element still no hot water!My question is what tells the element to heat up is it just in the program or a sensor some wear.if no sensor board is bad,board was changed 1 yr.ago
da
@stephenmjor5988
What is the model number of the dishwasher?
da
Aggiungi la tua risposta
Michele Bassett sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 13
Ultimi 30 giorni: 63
Tutti i Tempi: 2,883
