Salta al contenuto principale
Computer portatili HP Envy 14 dotati di display da 14".
Difficulty adapting to specific network
I just moved into a new home with an already established network. My computer is showing many other networks but not ours. My phone, ad well as my roommates’ Apple computers are able to connect but I was told that the network has never been discoverable on an hp laptop. I have tried a network reset, connecting/disconnect the WiFi many times, and resetting the router with no luck.
Questa è una buona domanda?
Punteggio 0
1 Commento:
Hi ,
What is the make and model number of the WiFi router?
What WiFi "channel" is being used by the router in your network? (you'll need to look in the router's setup area to find this information)
da
Aggiungi un commento
2 Risposte
Enter SSID (network name) by hand to connect it.
Punteggio 0
Try power cycling the modem one more time and see if that works.
  1. Unplug the modem and count to 30
  2. Reconnect the modem to power and see if you are able to connect to the network.
Punteggio 0
Aggiungi la tua risposta
karissa.nicole32 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 15
Tutti i Tempi: 281
