Salta al contenuto principale
Guide di riparazione e supporto per il pickup compatto Ranger di prima generazione, nella versione rivista. Il Ranger ha ricevuto un restyling e alcuni aggiornamenti meccanici per il model year 1989.
4 years without being started
Just replaced the fuel pump ,battery and emptied the gas tank put new gas but it still wont turn over , spark plugs are good as well as the coils and along with the spark plug wires& new relay . The fuses are good .has an after market alram system that no longer works with the clicker batteries were replaced .any one whos dealt with this kind of problem id appericate some help
Questa è una buona domanda?
Punteggio 0
2 Commenti:
Phillip Griego let us know what works. Do the lights come on? Do you have any sign of life on your Ford?
da Condividi
You said it wouldn't turn over. Do you mean there is no "cranking" when you turn the key, or that there IS cranking, but it does not start?
da Condividi
Aggiungi un commento
1 Risposta
You may need to pull the plugs and carefully hand crank the engine to break the vacuum seals and varnish buildup on the cylinder walls & pistons. When you store a engine for over 3 months you really need to add in an additive to the gas and fully fill the tank and you need to put oil into the cylinders to coat the walls (doesn’t take much).
Edmunds - How to Prep Your Car for Long Term Storage
Punteggio 0
Aggiungi la tua risposta
Phillip Griego sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 8
Tutti i Tempi: 330
