Salta al contenuto principale
La Keurig K55 può essere identificata dal numero di modello, K55 Classic Series. Rilasciata il 2 dicembre 2015, la K55 supporta sia le K-Cup che il caffè in polvere tradizionale.
No power into machine
I recently bought a Keurig K55 from bed baths and beyond. I was falsely sold this item by the sales rep. I asked if the machine would work in the uk and I was told to put a 3 pin adapter on the end of the plug and it would be fine. I done exactly this it started hearing the water and then suddenly stopped. Can I be told how to fix this and if I should use a voltage dropper convertor?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta più utile
Hi @veepatel
Confirm the input voltage on your Keurig K55
there should be a label mentioning about input voltage, e.g. 110V
In UK, voltage is supplied at 230V....
If your device is labelled at 110V and you connect it to 230V, likely is could be damaged.
I think you mean step down voltage transformer (drop voltage from 230V to 110V), you need to consider on your coffee maker power consumption also. Not all converter might be suitable of this.
update us first on your current machine voltage input.
Punteggio 3
5 Commenti:
I'm guessing I have damaged it. Yes the voltage is 110v. Is there anyway of repairing it?
da
Hi @veepatel
Well you may try opening up and check, hopefully would be just the power supply section is damaged.
take and share some pics with us
da
Sure will do when I get home from work. Thanks for ur help
da
Hi please find a picture below.
da
Does anyone which power supply I have to buy as in model number etc...
Thanks
da
Immagine
here is the picture
Punteggio 0
Aggiungi la tua risposta
Vishal Patel sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 17
Tutti i Tempi: 1,115
