How to replace blower fan
where and how do you replace a heater-A/C blower fan.
Questa è una buona domanda?
Alan,
1.) Check the fuse
2.) See if you can test the voltage to the blower motor. If you have voltage, you have a bad motor.
3.) Check the blower motor resistor if there is not voltage to the motor.
Either way, check out this PDF on location and diagram for replacement of both parts.
Regards,
Frank
Can you send me full manual link
This is a recall issue. Bad wiring causing resistor to burn out. Recal #15402
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 17
Tutti i Tempi: 10,417
