Salta al contenuto principale
La hatchback Tiida (Versa) e la berlina Tiida Latio hanno debuttato nel 2004 in Giappone e nel 2007 in alcuni paesi europei.
Reverse camera RCA cable
Hi There,
I have panasonic cn-hds625d and need to get a RCA cable for the rear view camera. Please advise what is that slot type called and where it is available. This car is currently in Newzealad and it is an Japan Import car
Sorry. Missed to update the image... adding it now.. Please also where i can get these cables in Newzealand.
Immagine
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
'''++ttsenkumar kumar++''' not quite sure which slot you are talking about. I suppose you are referring to the rear camera slot. You can always post some images of what you are looking for with your question. Use this guide Aggiungere immagini ad una domanda for that. That is most likely proprietary and without a proper schematic it will be extremely difficult to source it. I do believe that there is a rear camera kit for your navigation model Check for something like YESFX999101
Punteggio 1
1 Commento:
Thanks Mate... Just added the picture
da
Aggiungi la tua risposta
ttsenkumar kumar sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 8
Tutti i Tempi: 665
