Salta al contenuto principale
La Nintendo Switch è una console videogame portatile che può essere utilizzata sulla TV tramite una docking station, oppure in mobilità. Distribuita il 3 marzo 2017.
Strip screws? How to fix?
Hi i screwup my side console, by stripping one of the screws. ( i used a y00 instead of a y000). Rubber band and super glue didnt work. To remove glue i use a drill bit (1mm), now there is a counter sunk hole. Ideas?
Questa è una buona domanda?
Punteggio 8
Aggiungi un commento
5 Risposte
Soluzione prescelta
Sounds like you already have drilled a hole there so I would just get the next biggest drill bit and drill it more. You might even need to use the next biggest bit after that. Once you drill the head off then you can usually take it apart more until you can get to the screw and use pliers to turn it out.
Hope this makes sense.
Punteggio 7
Try this
Precision Screw Extractor Set
Immagine Four different sized extractor tools to help remove fasteners or screws with stripped heads. Driver head is claw shaped for maximum grip. Sizes range from 1.1mm to 2.0mm.
Prodotto
$24.99
Punteggio 3
Welp.. Y00 is correct you might have presed a lot. Y00 works for me
Punteggio 1
So how was this problem solved? I have the same situation. Please help.
Punteggio 1
1 Commento:
Needle nose pliers is what worked for me
Punteggio 0
Aggiungi la tua risposta
jonathan ambrose sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 6
Ultimi 7 giorni: 14
Ultimi 30 giorni: 52
Tutti i Tempi: 34,568
