Salta al contenuto principale
Released in June 2017 as a successor to the Surface Pro 4. Also known as Microsoft Surface Pro 12.3". Model number: FJT-00001.
20 Domande Visualizza tutte
Heat Gun/Blower for Screen Replacement
I am looking at purchasing a heat/gun blower to replace my Surface pro 5 screen (warm the adhesive to weaken it)....as well as for other electronics.
I have come across 3-in-1 Function Heat Blower and Soldering Iron (see link below), which I thought could be helpful with other projects also.
https://www.jaycar.co.nz/3-in-1-function...
Has anyone had any experience using this type of "heat blower"? First thought is it may be difficult to control the temperature...although it does have a flame adjustment setting.
Thanks in advance for your help.
Questa è una buona domanda?
Punteggio 1
2 Commenti
Hi @dgmossman ,
You may wish to take note of the warning at Step.1 in the ifixit Sostituzione schermo Microsoft Surface Pro 5 guide.
Just a thought.
da
Go for an iopener, otherwise it's too easy to damage the surface.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
I think the soldering gun you picked will be to narrow an area and far to hot to do the job well. I believe you chances or success on this repair would be much greater with a standard heat gun:
Heat Gun
Immagine Loosen adhesive or reflow solder with this 1500W heat gun. Low setting reaches 570 degrees F (300 degrees C). High setting reaches 1112 degrees F (600 degrees C).
Prodotto
Heat Gun
$24.99
Punteggio 2
Risposta Più Utile
I would use the iOpener or a heatmat.
Punteggio 2
Aggiungi la tua risposta
Daniel Mossman sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,303
