Salta al contenuto principale
L'Asus ROG Strix GL702VM-BHI7N09 è un computer da gaming rilasciato da Asus nel gennaio 2017.
Replace broken internal speakers?
I bought new parts for the internal speakers, but I'm not sure how to install them. I have updated the audio drivers several times previously but to no avail. My guess is an acquaintance of mine accidentally blown the speakers resulting the problem.
Update (04/01/2018)
The audio worked fine when I was using my earphones.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Hi,
Is the audio OK when using headphones?
If not then perhaps the speakers are not the problem and you may have a problem with the audio controller.
As it is most probably mounted on the motherboard, the simple way to get around the problem would be to use a USB sound card.
Update (04/01/2018)
Hi,
Just covering all bases. ;-)
Cannot find a speaker replacement guide for your laptop but here is a link to the ifixit Sostituzione hard drive Asus ROG Strix GL702VM-BHI7N09 guide, which should get you access to the motherboard. Hopefully it will be easy to see how to replace the speakers once you have got that far.
Punteggio 1
Aggiungi la tua risposta
Faiz Zailani sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 11
Tutti i Tempi: 1,080
