Salta al contenuto principale
Cuffie da gaming USB che offrono un'esperienza di gioco completa con audio surround 7.1.
USB Wiring Not Working HELP PLEASE
Hi,
I have got fed up of cutting the cable and then soldering the two parts together because they always break anyway so I decided that I’m going to cut the wire and directly connect it to the USB however it doesn’t work.
I didn’t see which colours go where before desoldering them so I looked up the colours online and soldered them but not the headset is completely dead! I will appreciate if someone is able to help me out. I will attach a picture below. Thanks
Immagine
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Sorry but stupid me wired the USB port the other way because you have to flip the USB plastic to put it in the case and that means that the wiring that I have goes the other way around. Sorry about that
Punteggio 0
1 Commento:
Good learning!
da
Aggiungi la tua risposta
Tom sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 16
Tutti i Tempi: 1,899
