Salta al contenuto principale
Il Kindle Touch (D01200) è la quarta generazione di eReader prodotti da Amazon. È dotato di connettività Wi-Fi o Wi-Fi/3G; tutti i caricamenti vengono effettuati tramite cavo USB. Dispone di 4 GB di spazio di archiviazione e due mesi di autonomia della batteria.
My power button does not work
Power button does not work, e-reader appears to work correctly once started via USB cable into a PC but no other method that I have seen put forward in various articles seems to work including multiple resets, pressing power button for 7, 15, 30 secs. disabling screensaver etc. Guessing this has to be a hardware problem, but if anyone had any other suggestions or options to try before I dismantle this great bit of kit, please let me know. Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Go ahead and take it apart it's easy just remember how the screws are placed. Then remove the battery and remove the front panel. After that go ahead and gently press the power and the home button with your screw driver. When you remove the motherboard there is going to be a square with four pins. Go ahead and clean this square. After that screw everything back how it was and your kindle should work.
Punteggio 0
Aggiungi la tua risposta
The Dan826 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 14
Ultimi 30 giorni: 53
Tutti i Tempi: 622
